johnson/evinrude mid '80's control box
Dali30
Thing is the ignition switch is gone,only the wiring conections behind it is left,all wires are still conected to this back-ring i call it. when i connect cable pluss and minus on batteri,the starter cranks right away,have to remove minus cable and then it ofcourse stops.
pic is random google.
colors is: two black,one red,one purple with white stripe,one black with yellow stripe and one white.
im asking, if i remove all wires from this ring,wich one should touch eachother so i can start it "normally" with cables constant connected to battery?
Dali30
Re: johnson/evinrude mid '80's control box
....new ignition switch is bought,but i cant wait two weeks to really fire it up:(
Dali30
awsome,thanks mate.
Dali30
its just to complicate,il wait for the new ignition switch to arrive first.
71Windsor
if the new switch is a sierra brand I would strongly suggest double checking the markings on the new switch as to where each wire will go. ign.jpg
