Johnson/Evenrude 2 cycle oil
nightstalker
Wal-Mart sells Johnson/Evenrude 2 cycle oil for about $17 a gallon. I see Penzoil for about $11, Wal-Mart brand for $6 and Bombadier for $20. I have been using the Johnson/Evenrude oil, should I stay with it, or are any of the others just as good. Also, if Bombadier bought out OMC, why is there Johnson/Evenrude and Bombadier 2 cycle oil. Is this J/E oil the same stuff you would buy at a dealer?<br />Stalker
JB
Re: Johnson/Evenrude 2 cycle oil
Moving to General Outboard for this week's debate.
Xcusme
JB, Thanks for the heads up...!!!<br />I'm going to get the popcorn....<br /><br />Ok, I'm back, let the games begin... :p :D :rolleyes:
nightstalker
I didn't think this would open a can of worms, but what the heck, let the fireworks fly!!!!!!!<br />Stalker
cobra 3.0
The Wallmart stuff is what I use. No complaints here. ;)
nightstalker
I should have told you that I run a 1994 225 HP johnson and that I premix at 50:1.<br />Stalker
walleyehed
The specific "BOMBARDIER" oil is for injection systems on PWC's and Snowmobiles only.<br />the Johnson/Evinrude name is maintained on the containers to clarify the use for outboards...<br />I've learned a ton on this forum, and I'm fixing Pop-corn as I type, and plan on "watching" the post this time.... :D
seahorse5
Be sure you look carefully at the oil bottle labels. For outboards, you want to see the NMMA<br /> TC-W3 certification logo for outboard motor use. The new packaging from Bombardier says Johnson and Evinrude on it and is called XD-25, and will soon be changed to XD-30.<br /><br />Bombardier also makes 2 stroke oil for snowmobiles, etc. as was posted earlier and it is NOT for outboards.
roscoe
My store has, all are TC-W3 and nmma:<br />Pennzoil, $7<br />Pennzoil Blended, $13<br />Pennzoil Synthetic, $19<br />And.......<br />Pennzoil Bio somethin or another. $22<br /><br />They also have WD-40 for $9.99, and corn oil for $3.99, so I think I'll switch to one of them. :p
TPD211
OK, I'm a newb to boating but have owned PWC's.<br />I sold the PWC's to buy the deckboat.<br />This is a great debate in PWC circles also. :D <br /><br />I tend to go over board when it comes to the oil I use. I could run the Evinrude XD25 or any TC-W3 oil and get by...<br /><br />I choose to run Amsoil Synthetic in my 2 stroke engines. It's 20 bucks a gallon. <br /><br />I like the protection this oil gives and it does not tend to break down at higher temps. Two conventional oils also give great heat protection and those are Castrol and Kendall oils.<br /><br />I'll run the Castrol 2 Stroke Synthetic if I cant get the Amsoil.<br /><br />My 2 cents worth... :cool:
WillyBWright
Just how hot do you think that oil is running at? I mean, it sucks in, it burns up, then it's blown out. It doesn't recirculate like on a four stroke. That's the neat thing about 2-stroke oil. It doesn't get dirty as the motor runs. You never have to change it. You get fresh oil with every intake stroke. The motor would lock up long before oil temperature would be a problem in any way, shape, or form. (There's my contribution to the debate. Next...)
Melvin Hatcher
Hey walleyehed,<br /><br />Make enough pop-corn for me and I will get cokes for both of us so we can enjoy this debate. ;)
walleyehed
New batch in the Microwave.....give me a few minutes.... :D
JB
Hey, Catzilla!<br /><br />Bring me a beer and some munchies. :)
BillP
Is this J/E oil the same stuff you would buy at a dealer? <br /><br />Yes. :D
Sand Bass
I use pennzoil synthetic blend...premix 50:1. Never had any problems...inside of motor is clean. Decarb twice yearly. 1994 Evinrude 225hp
nightstalker
Ok, do you think the synthetic 2 stroke oil is better? Does Johnson/Evenrude make a synthetic? All out of popcorn, switching to peanuts!<br />Stalker
JB
Care for a chaw of homemade venison jerky, Stalker? Mesquite smoked.
seahorse5
Nightstalker,<br /><br />J/E have had a biodegrable synthetic oil for years. It is now being reformulated and called XD-100. You will see it more and more as it is the oil recommeded for the new E-TEC series. It ain't cheap, but it works very well and is recommended for oil injected motors when used in freezing temps.
LubeDude
Hey JB, Ill go for some of that Venison Jerky, Havnt had any sence my Grandfather passed!<br /><br />Oh, Oil!<br /><br />JPD211 Has it right, The main reason I would go that route is that you premix! Your injection system would have cut the mixture down to about 100:1 at Idle so you are going to get a lot more smoke and fowling at low RPMs! If you go with the Amsoil, use the Injector oil at 50:1! You will be very happy with it!
