gm280
- Jun 26, 2011
- 14,605
I have researched cork float issues on here and read a lot of interesting posts concerning them. I too have an old Johnson 40 HP OB engine and it has a cork float that was literally covered in a black crappy tar like substance when I disassembled it a few days ago to rebuild it. The original sealer on the cork has long since dissolved and the only thing left was the cork itself (actually under all the tar). I obviously looked to purchase another float but only could find the original shellac coated cork versions which will not work with the ethanol fuels used today. SO, I tried to see if they made a plastic version like they do for some other models. I see lots of plastic floats for smaller OB HP sizes, but haven?t seen one listed to work with this 40 HP engine. However, has anybody tried to recoat these cork floats with a two part epoxy type coating to work with today?s fuels? I use to fly R/C aircraft and used two part epoxy to saturate the engine compartments so the fuel would not penetrate the balsa wood frame with the nitro methane, alcohol and oil based fuels. It worked great too. Just wondering if anybody tried this on these cork floats? Any ideas or part numbers for other type floats..? Here are a few pictures of what I had...
