Johnson Coil Replacement
Coork
How do you remove coil wire from connector on Johnson V-6. Manual calls for special tool 322697 and 322698 pin remover and socket remover. Have cracked coil and do not want to wait a week for special tool.
mikesea
Re: Johnson Coil Replacement
spray the connector with some WD40,for the pin,reach in with a small needle nose and push it so it comes out the back,after it has exposed the crimped connections,grab it and pull til its out,to install .start with needle nose,then either CAREFULLY grab inside the connector and pull,or use a small awl or nail to push into place,you should feel it seat,if not just adjust to length of other pin coonnections,often when removing,once you get it started a tug on the wire will do the trick,but if u want to save the coil its not suggested
