Johnson CD-12 water pump parts
mina_itse
I am going to change the impeller. I need part numbers for the impeller , water line rubber bushing and power head base gasket.
I read some where there is 2 gaskets at the base?
is there anything else i should change at this time?
Thank . Eero
HighTrim
Re: Johnson CD-12 water pump parts
Impeller is part #277181
Water line grommet part #302497
Base Gasket is part #303467
Change the o ring at the top of the drive shaft. Re grease the splines before re installing.
