I am running a 1958 Super Sea Horse, 35hp, model RDS20. My manual says don't use carb dip to clean the carb because it will remove some kind of sealing compound applied during manufacture and cause porosity problems.<br />I use carb dip on every other kind of metal carb so I can't help wondering if this advice is correct or not. What do you do? Ever had a problem using carb dip on a Johnson carb of this vintage?
