Johnson block venting
AUGIDAWG
I had heard you guys talking about venting the block to keep the voltage rectifier from over heating from the "air bubble" effect.<br />I talked to my Johnson mechanic. He said he has never heard of this problem from the OMC company. He said, if there was a problem, they would have sent out a bullitin to modify all engines coming in for any repairs. And, that Johnson does a lot of testing before they release a new design out into the market. In this case, a cheap modification would save them millions in warrenty repairs. He also said, if there was an air bubble, as soon as you throttle up, the bubble would dissapear.<br /><br />I did a search on this topic, and have found that "DHadley" is the only one recommending this modification.<br />I too have melted a voltage regulator, and want to get down to the bottom of this modification suggestion.<br /><br />Here is my question:<br />Has anyone had first hand information on this subject, either from OMC, or from proof of "failure mechanism" leading to the overheating of the voltage regulator?<br /><br />Remember, if you vent the top of the block, when you stop the engine, all of the water will run out of the back into the lake, leaving you with hot metal awaiting cold water to run in.
Dhadley
Re: Johnson block venting
Actually some newer designs have made an attempt to "vent" the block in a higher location. Some of the 56 cid motors have a factory mod to move the overboard indicator higher to help eliminate hot spots.<br /><br />Not all blocks (nor models) do it but it cant hurt to do yours, all though you didnt mention wht you have.<br /><br />In theory the air trapped at the top of the block should be forced out under pressure. However, in the real world we have found that some still trap the air. <br /><br />Lets put it this way -- any motor we found with a burned reg/rec that has this mod done has never again burned a reg/rec. Even on ones that were repeat offenders before. Any motor we have done this to, even though there was not a burned reg/rec, has ever burned one. Short or long finned type reg/rec.<br /><br />In the worst case scenario it cant hurt anything. You do not lose any more water than currently comes out of the indicator hose anyway.<br /><br />To be perfectly honest, that wasnt the reason we did it to start with. It just so happened it cured the reg/rec problem.<br /><br />Good luck!
seahorse5
The '93 thru '96 200-225 OMC blocks needed venting for the regulator under certain conditions only. At the service schools and clinics, they recommended a drilling a 1/8" hole in the center of the "blow off" valve on the back of the block. In 1997, they came out with a sloted valve that does the bleeding and recommend them in all earlier engines that were not drilled.
