Johnson 90 Steering
Drewmac
My Dad and I wanted to get out the C. Skiff, but found out the steering wheel would not turn. It worked fine the last ride of last year. Have a manual on the way, but thought I would still try to get other help. I believe it is a manual type. Dad states when he takes the cable loose from the motor that the wheel turns freely and so does the motor. Put the cable back in and nothing budges. Any help appreciated. Thanks!
tashasdaddy
Re: Johnson 90 Steering
did he clean the tilt tube when he had the cable out.
Drewmac
No...Pretty sure it wasn't cleaned. Probably should have also noted that the boat is in a good ole salty environment.
