I've got a 1989 90HP on my Ranger. Went to start it this morning - turned over fine, no pop. Took the cover off, and saw a leak.
On the starboard side, there's a small cylinder (3 in x 1 1/2 dia) that has a red plastic lever, attached to the cylindrical part. The post holding the lever has what looks exactly like a tire valve, right down to the plunger in the middle. The gas is squirting from the base of the lever, presumably where the tire valve thing goes into the cylinder (it has a square base holding it down with 4 screws). I see no way to remove the valve.
So, 2 questions - what is it, and wll I have to replace cylinder and all, or the base plate of the valve, or is there some fix without buying parts?
