Johnson 9.9hp Oil/Gas Ratio
Gmonst
Howdy. I have an old Johnson outboard motor and we can't quite remember the oil to gas mixture ratio for it. I don't know the model number, (it's up at our cabin, while we're here at home, preparing to leave), I only know that it is a Johnson motor, with 9.9 Horsepower from the '70s, and it looks identical to the attached picture that I found on the internet, which labelled it as a 1976 Johnson Seahorse 9.9hp, or something along those lines. Relevant answers within the next 24 hours are greatly appreciated. Thanks.
F_R
Re: Johnson 9.9hp Oil/Gas Ratio
50:1 TC-W3 outboard oil and regular unleaded
Daviet
Yep, 50 to 1 ratio is correct.
the machinist
Welcome to iboats & since you are a new member here, we will overlook that you are questioning a member with over 18,000 posts.
Gmonst
My apologies, I made this account just to post this question and I was just trying to be certain. Thanks for all the help.
Tim Frank
Can anybody confirm this?
Actually, if you want to be picky, the correct "oil/gas ratio" is 1:50.
I assume that FR was just too polite to point out that you asked backwards. :)
Welcome aboard.
