Johnson 9.9 WIll Not Idle Properly
DaveinTampa
Ok, so here I go again. I posted about three months ago on this but didn't have motor info. The motor is a 9.9 hp Johnson, year 2000, serial number G 04775613. It is NOT an electric start. It starts up fine but I have to have it at high rpm to keep running when out of gear. I also have to shift at fairly high rpm. Once in gear it seems to run at any speed, even low rpm, just fine. This is a pain because it dies when I shift into neutral at low rpm, therefore causing me to constantly rev up the engine to keep it running when out of gear. Please help!!!
duck64
Re: Johnson 9.9 WIll Not Idle Properly
read the post above
