Johnson 9.9 electric start problem
thatone123
Banned
I have this Johnson 9.9 that I recently converted to a 15. The electric start only works when I turn the motor tiller to extreme right. I have checked the connections and sandpapered the metal to a bright shine and still get this. It worked in any position when I got the outboard a week ago. I was running a Tohatsu 2 stroke 9.8 and am amazed at the increased power with the Johnson for pushing a load. Why is the Johnson so much more powerful besides the larger prop? This was even when it was just 9.9 relatively same HP as Tohatsu. I have not run the 15 conversion carb unit yet! I bet the power must be awesome for this size of a motor.
Honorary Supreme Mariner
You may have a loose ground connection INSIDE the starter motor.------------I have repaired that riveted connection by putting a small bolt and nut in it's place.
F_R
Since steering affects it, I suspect a problem with one of the battery cables, or end connections. But I'm guessing.
There should be 2 identical switches.-------One is installed as the push button start switch and one is used as the " start in nuetral only " switch.---------Perhaps that nuetral switch needs adjustment.
oldboat1
On my mid '80s 9.9s, the neutral switch is down in the pan under the shift lever (cam contacts switch button). It's a positive wire through the switch, under the rear of the powerhead to the starter.
The wires for the starter button are pretty cramped up under the front of the steering bracket. It might be worth checking to see if there is some abrasion or similar issues -- could be the problem. The ground wire runs under there too, as I recall. (The engine ground point is down on the front of the pan, probably hidden by the rewind starter.)
If you take off the plastic nut holding the starter button in place, you should be able to push the button assembly down and out to check the wiring.
thatone123
Banned
Thanks Guys! I have been out duck hunting and am back for a while now! I checked a lot of these above items. I notice that when I loosen the plastic nut on the main switch it starts sometimes, but frustratingly not a lot too. I will check that natural safety switch today.
flyingscott
Check the cables going into the start switch they could be getting pulled on when you turn causing a bad connection.
