Johnson 9.5hp Fuel Pump?
excoelis
Hi all. I have a Johnson 9.5hp outboard, which I believe to be a 1969 9R69S (ID plate is missing from motor) and I think I need a new fuel pump. When running, especially anywhere above idle, the motor will die unless I keep pumping the primer bulb... then it will run all day long. If I stop pumping, about 20-30 seconds later as I mentioned the engine dies. Prime bulb again and starts no problem. I am new to outboards, but from my research on these forums, I believe I have a faulty fuel pump. Any confirmations or suggestions would be appreciated.
The real problem I have is that I have been unable to locate a new fuel pump on iboats or elsewhere, oem part # 382224. Does anyone have any suggestions with this problem?
Any help is much appreciated, thank you.
klicknative
Re: Johnson 9.5hp Fuel Pump?
Try SeaWay Marine in Seattle. sea-way.com or 206-937-7373.
excoelis
Is there no aftermarket version of this pump by sierra or other, or am i stuck looking for a used one? some of the pumps i've seen listed look identical but are not referenced for this motor.
Does this in fact sound like the problem though?
F_R
Sounds like it is the problem. I don't want to lead you to buy one that might not fit, but it looks like an 18-7350 might work. The only difference is the small hose fitting comes out at a different angle. If you could re-route the hose without interferrence, it would work. It's kind of close quarters in there.
ezeke
I've used the Sierra 18-7350 that F_R mentioned with no problems. The current OMC/BRP pump number is 397839. There are also rebuid kits if you wanted to restore what you have.
http://www.sschapterpsa.com/ramblings/Rebuilding_fuelpump.htm
Check that the gasket between the engine and the fuel pump is airtight and that the screen in the intake of the pump is clear before you buy a new pump.
I would strongly recommend against buying a used fuel pump.
excoelis
Thanks for the help guys. The Sierra 18-7350 looks like my choice then. Ezeke, I want to check the screen you mentioned first, but I'm worried that if I unscrew the filter cap that it will not seal back up without a new gasket. Is that normally a problem? Also, does the sierra kit include all gaskets and the screen that are required? Thanks again.
F_R
The new pump comes with the cap and screen already installed.
