Frydaddy84
- May 7, 2017
- 2
I recently purchased a Johnson 9.5 short shaft tiller engine. I went to pull started the string came out and is now stuck. I took the recoil assembly off. I found there is nothing at the bottom to hold the little slot so I can put tension on the spring. My question is does anybody know what goes there to hold the bottom of the starter assembly? Thanks to all
