Ok I am at wits end because I dont want to pay money to someone to install this thing back on. I took off the tiller arm so I could get to the gas input to change the fuel line. With the arm in place I couldnt get a good angle to install a new fuel line there. So I took it off and now I can get it installed back on correctly. The mechanism is a simple procedure so I thought it wouldnt be hard to put back on. Just a gear (the end of the tiller handle) that slots into another tube gear. If you have seen it, you know what I am talking about. This is held together by 3 bolts that screw from the inside of the motor and grab the arm. I cannot get this thing back on there correctly for some reason. The gears sometimes seem to work right with the throttle and sometimes not, sometimes it feels like they jam up. Sometimes when you twist it either way it doesnt stop where it is supposed to. Used to it would stop at a certain point either giving it throttle, or backing off the throttle. Basically I was just trying to find someone with experience putting a tiller arm back on a johnson motor and to tell me what I am doing wrong, or how you did it.
thanks
thanks
