johnson 8hp will not idle
petryshyn
Re: johnson 8hp will not idle
have you cleaned the carb? Does it idle with the cover off? (may have exhaust leak if it does)
Daviet
You have a low speed adjustment on your engine, you might try adjusting it. Most likely it's time to overhaul carb.
