Johnson 8hp J8RENM 1992
2ippy
Hi guyz,
After around 15 years idle in the back of my shed, really good nick. Only slight surface rust on the mount bracket.
Engine runs, but no clue where you meant to keep the throttle grip, to idle at.
Thermostat seal is leaking, which is an easy fix, is there a torque setting for them 3 bolts?
I had it running on the side of an wheelie bin, but can't figure out how to adjust the pitch. It wont freely move, but did before we put it on the wheelie bin.
How do I lock and unlock the pitch to adjust?
If anyone has a link to the manual would be appreciated, need to jog the noggin.
Thanks
Damien
Vic.S
Twist grip fully clock wise to idle
The knob on the end of the tiller is the idle speed adjustment.
The thermostat cover bolts are quite small so not very tight. 5Nm perhaps
Service manual at http://boatinfo.no/lib/evinrude/manuals/1990-2001johnsonevinrude.html
Owners manual (and shop manual) available from Ken Cook at https://www.outboardbooks.com/manual/J8REN/
Knob similar to the one arrowed in picture below turns 180? to release / engage the tilt lock
Not advisable to run them in wheelie bins. See second picture below
2ippy
lol, i jet washed mine clean and filled with water :D
