Johnson 88 weak spark but runs very good. At lest one cylinder getting weak spark. Connection between power pack and coil got wet in the past(before we got boat) because they show some rust and corrosion. Have cleaned them up but will probably get new mini coil boots and the connectors that go inside to see if that helps. In the mean time I am going to try to trouble shoot and check powerpack and stator with CDI instructions. Any tips? Boat has a miss in the mid range rpms. Tach dead so dont know rpms of miss but it is not at the exact same rpm everytime. Waiting on new tach
