Hello!<br /><br />We have a Johnson 85 or 86 VRO 60HP on our pontoon. Last year we replaced the oil pump b/c of the nasty alarm going off and some fuel leakage on the water when we would start up. Solved the fuel leak problem not sporadic alarm. For our maiden voyage this year- alarm started going off when going slow with prop up. (actually had one day with no alarm) I read in postings to shake the reserve b/c float sensor might be getting stuck- do you mean shake the oil tank? After the alarm started going off - we pulled the accessory plug and then when we put it back IN the alarm stopped, then all the gauges went dead with boat still running I noticed fuel smell/slight smoke at this time. We kept going slow and then decided to try turning off and resetting. Big Mistake! No power - no nothing (only radio worked).
(thank God for kind neighbors and cell phones) I had noticed earlier and end of last year that the tilt was shorting out a little as well as gauges. Do you think the alarm is the oil alarm or overheat alarm and do you think it's related to the gauges wiring. What should I ask the repairman who is coming tomorrow to do in order to help our chances of a fun summer with little or no boat trouble nightmares. (it is so hard to get someone to come out - takes so long, that I want to make sure all bases are covered)<br /><br />Thanks in Advance,<br /><br />Tori
