Bill Foote
- May 27, 2009
- 15
1987 Johnson 70hp 3cyl. block:
So, I have been trying to get this engine running and..... not so good
Here is my observations thus far:
1. Carbs are cleaned and bench synched the throtle plates, fuel is flowing to the carbs and they are carbureting as they should do...
2. Reeds are seated and do not appear chiped, broken, or bent.
3. compression is 130, 128, 129 respectively
4. nice thick blue spark on each plug.
So whats wrong then???
1. After cranking the engine with a good charged battery and fresh fuel, the engine doesn't run, maybe a pop now and then...
2. Cover carb throats with rag while cranking to flood them out.. still nothing
3. Removed spark plugs after flooding carbs... Bone dry
Conclusion:
Fuel is not getting to the cylinders, but it is flowing to the carbs...
Suspicions:
1. Upper and/or lower crank seals are leaking
2. Is there supposed to be a gasket in between the 2 crankcase halves or is there an oring seal?
3. Can the upper crank seal be replaced without tearing the powerhead all the way down?
*4. If the seals were bad on the crankcase, would you still have good vacuum on the throats of the carbs?
5. Could the exhaust system be clogged???
Any suggestions?
Thanks in advance
Conclusion:
Suspicions:
Any suggestions?
Thanks in advance
