Johnson 70hp block on 90hp lower ????
Valv
I have one of my "projects" going. A 70hp 3 cylinders Johnson with bad lower unit and a 90hp V4 with bad powerhead. Question is, can I install 70hp onto 90hp ? Does the exhaust plate and water passages matches or it's a lost battle ? I don't want to dismantle 70hp to find out, unless it will fit.<br /><br />Thanks.
jegervais
Re: Johnson 70hp block on 90hp lower ????
They're totally different, don't waste the time.<br /><br />-John
Valv
John, it would have been nicer if you lied to me..... ;) <br /><br />I was kidding, I just had the "brilliant" idea looking at the 2 together.<br /><br />Are you sure a little epoxy and small welding job won't do it ???? :D <br /><br />Thanks.<br /><br />Val
jegervais
Thats a thought. Do you have a Sawzall?? :D <br /><br />-John
