Muletrain9
- Jun 14, 2022
- 11
I've never worked on johnson outboards before so this will be the 1st of quite a few questions that you all can hopefully help me with.
Bought a boat cheap with a 1989 70 on it. The lower unit was sitting in the boat and the owner had little to no knowledge other than it had run about 10 years earlier. So I figure I'll mess with the lower unit first. It seems to shift into gear ok, but when it goes from neutral to either foreward or reverse, it has slop in the gears. Meaning I can put it in gear and when I go to turn the prop, it takes about a third of a rotation before the gears engage and the shaft spins. Is this a normal amount of play? I'd think it's a bit much, but what the hell do I know? Any experience out there?
