Re: Johnson 70 hp 3 cyl died & won't start
Welcome to Iboats!<br /><br />Gas, Spark, Compression... The 3 things needed to make a motor run... Basically.<br /><br />Like my Dad used to say<br />1. Does it have gas and is the vent open? (the vent always got me when I was young)<br />2. Do the spark plugs have spark?<br />3. What is the compression readings?<br /><br />The first 2 are easy to check with minimal tools. The 3rd requires a compression gague. Which you should get if you plan on being a DIY'er (Do-it Your selfer).<br /><br />If it has gas in the tank, the pump bulb is firm, and the spark plugs have spark, try squirting a little pre-mix in the carbs to see if she'll fire up a little. Then go from there.
