-1989 J70TLCEM- Installed a Blue Seas Dual Circuit Plus Battery Switch #5511E(Off-#1-Both) and Blue Seas ACR(Automatic Charging Relay) 7600 . With #1 selected, the two banks will be automatically connected when the voltage reaches 12.5. And disconnected(overvoltage) if voltage exceeds 15. The idea, when #1(starting) has recovered from startup duties, the relay closes and #2(house) gets hers. Electronics are on #2 and isolated. These settings are adjustable. It has worked splendidly until Sunday. I started the motor and quickly the #1 voltage spiked to 17.5+. I then selected "both" on the battery switch(make before break) to rein in the spike. The electronics blinked and the control box emitted a steady scream. This is the sound of an overheat condition(which I didn't have). I killed the motor. Returned switch to #1. Key on. Steady scream(motor still off). Selected switch to "both". Motor started normally with no alarms. Ran all day. Normal voltage on both banks. Charging normally. Tachometer normal. I occasionally stopped the motor and selected switch position #1. Key on, steady scream. Back to switch position #2 and all normal. I checked all battery connections(wingnuts, I know). They SEEMED fine. Does this sound like a defective battery, battery switch, or ACR ? Or should I more closely examine my wiring again ? Perhaps wire-wheel the #1 battery terminals ?
