mooring
- Feb 5, 2012
- 8
I bought a used Johnson 6 hp, circa 1978, last summer. I ran the water out of the water pump and ran some Stabil Gas through the carborator--all I did before storing it in the garage. I just checked in on it and there as a considerable amount of what I assume is gear lub/oil on the floor of the garage. There appears to be some kind of hole under the anticavitation plate that could have been the source of the leak--I don't see any oil higher up on the lower unit (stored in the down position). Here are a couple of pictures:
![photo[1] (2).jpg photo[1] (2).jpg](https://forums.iboats.com/data/attachments/111/111118-dae834f59fac8b29cf7ff4be68f552e8.jpg)
![photo[2] (2).jpg photo[2] (2).jpg](https://forums.iboats.com/data/attachments/111/111119-2a1ae0917eb34316f4b6a90584374a11.jpg)
Seems to be what I would call a "blow out" or "pop out" that pushed out a circlular area of the finish down to the bar aluminim. Then in the center there is a jagged/rough raised area. Was to dark to tell if the hole went all the way through, but it is right at the juncture of the lower unit body and the anticavitation plate on the over side of the cavitation plate.
What is my next step?
