Hi--I have a 1972 Johnson 50HP with the Hydro-electric shift. It works great but on engine shutdown the lower unit "thunks" into forward. The book says that the shift diode (aka "monkey balls") is done. I don't want to pay OMC/Bombardier $70+ for this thing. It appears to be two diodes in series? parallel? (three wires) but since they currently read "open" in all directions I can't figure out the original current flow direction. The purpose is to maintain current to the neutral solenoid for that one second after ignition is turned off. I can buy diodes from Radio Shack and wire them in if someone can tell me which one goes in what direction...or if you have one that works and don't mind putting an ohmmeter to it and tell me which wires have continuity and which show open, I'd really appreciate it!
