Our boat ran fine last season. We pulled it out in Sept and had it winterized and shrink-wrapped for the winter. I was there when it was winterized and I know it was pee-ing then.
Last week, I put the muffs on and the motor fired right up. However, no water from the telltale. I verified the tubing was not clogged and even used an air compressor to blow air in the indicator hole (with the swivel-thing removed). Air came out the intakes and a few other holes in the lower unit.
The impeller was replaced mid-season last year.
The guy who did the winterizing mentioned that there seemed to be a slight amount of water in the lower unit oil when he drained it.
What would be the next steps? I'm thinking I need to drop the lower unit and check out the impeller.
What about the water in the lower unit oil?
Someone mentioned it could be a bad water pump, but I thought the impeller was the water pump...
Forgot to mention - this is an '03
