Johnson 48hp special Outboard running problems.
TyeCope
Hello!
I have a Johnson 48hp spl outboard, the model number is j48eslenb. I am having problems with it staying running and i can give it throttle and it instantly dies. It has strong spark, good spark plugs, and good fuel flow. It ran about a year and a half ago but it was running a little rough and would not run at full power. Any help is appreciated. Thanks!
Any and all trouble shooting starts with a compression test.-----Post the numbers Here.-----Mixing gas and oil at 50:1 in the tank ?
LITTLE bits of information in your reply, means we can only be of LITTLE help to you.----Don't be shy, post all the information you can.----And answer questions.
