hooter85742
- May 6, 2011
- 12
Ny Mom and I just bought a 14' Scorpin ski boat with a 40R72E Johnson on it. As far as the engine I know it is a 1972 40hp it has no wiring for a choke, no tilt motor, eletric or pull start. The shifter is a cable that does forward net and reverse. The other cable is the throttle. The carb was just rebuilt so they said, but they never started it. The wiring is all unhooked by the ign switchand a few wires are not hooked up at the engine. I messed around and did get it to fire and run for a few minutes. I put a 35 gal trash can filled with water, so I did not mess thing up by over heating it. Its not fun but It does not have the spot to put ears on it I think. I put two new a/c delco R45 plugs in it gapped at .30 like I found at Johnson's website. I think if I can get the wiring right everthing may be okay. I can not find the right wiring for this engine. I have a starter switch and a switch for the lights and nothing else. The harness has Red, White, Blue with a White strip, Blue, and Purple. I know red is hot, white is the start. If someone can help me out with some information about this engine and the wiring. And if I can hook a Volt meter and Tach up also. Thanks Hubert
