I've got the 1970 electric shift johnson on the boat now, and hopefully everything is ironed out and it's ready to go.
But, I was told by several to have another motor ready to go because the shift solenoids aren't real reliable.
So I've got 2 1968 Johnson 33hp engines that are complete. One is complete but low compression. The other is a complete motor, just in pieces.
Will the 33hp lower unit swap onto the 40hp and what all would I have to change out to make it work?
Or will the extension at least work so I can make my motor a long shaft, I feel it would work just a little better. I have the extension and the driveshaft for the 33hp engines. Will that at least work on the 40?
