Hi All: I've got a 1998 Johnson 4HP outboard, which I THINK, has some carburerator problems, and I'd like to see if anyone else has experienced the same thing. The motor starts and idles fine, however, when I start to apply some throttle, it tends to bog out. After I slowly get it up to about 3/4 throttle, it seems to run fine, however, if I drop the throttle too quickly, it bogs out again. Anyone else had the same problem, and if so, how did you correct it? I've replaced the plugs, so that eliminates ignition problems. I'm thinking maybe the main jet is clogged? Thanks in advance !
