Johnson 4.0 Deluxe
macaroo
Just bought a Johnson 4.0 Deluxe that was intended for use on my inflatable. However, after a test run I think I will put it on my sailboat and use the Yamaha 4 (currently on the sailboat) for the inflatable.<br />The Johnson seems to have more guts and is definitly quieter than the Yamaha. (perhaps because it is a twin?<br />Any comments to this?<br />My questions are What is the difference between a Johnson 4 and a 4 Deluxe?<br />What year would it be?<br />The model # is cj4rdhce<br />Than you in advance.<br />Great site!!!
JB
Re: Johnson 4.0 Deluxe
Howdy, Macaroo.<br /><br />Welcome to iboats. :) <br /><br />The model number is a bit confusing to me, but I think you have a 1989 engine. <br /><br />I can only speculate, but it may be that the Deluxe has a gearshift.<br /><br />Really great little engine. One of the best small outboards ever made. . .by anyone.
handball
Macaroo,<br />I also just got a 1990 johnson 4 h.p. with a sail boat recently. I agree with JB the delux means it has a shift, but my engine has a shift with only foward and neutral . For reverse you have to spin the engine around and have it in foward. Its a little bit to get used to but I think it is well worth it considering how smooth and steady the engine runs. I also have a Nissan 5 that runs well but because of the single cylinder it has a lot of vibration, enough to put my hand a sleep while holding the tiller. The other advantage is the johnson came with a 6 gal. remote tank, it should run a long time on a fill up.<br />Does your 4 johnson have a lot of plastic parts?<br />Mine has a upper and lower plastic cowl, and also a plastic shroud around the upper leg. <br />Good luck with your engine,<br />Bill
ratracer
If you picture taking a same-year 6HP JohnnyRude, removing the powerhead, and grafting on a 4HP powerhead instead you've pretty much got a 4 Deluxe.<br /><br />The big functional difference between the 4 and 4 Deluxe is that the 4 Deluxe has a F-N-R shift and weights about another 13 lbs.<br /><br />I have a '91 Deluxe. Its good for trolling, smooth and quiet at idle. With me and a 6 gallon tank it can just barely manage to get my 12' aluminum boat up on plane in calm water.
