brownie777
Thread starter- Joined
- Jul 17, 2009
- 3
OK, picked up Johnson 3hp and broke it down to cleaned everything, full powerhead gasket kit, carb rebuild, plug wires, plugs, impeller kit, cleaned tank, tank petcock and filter stone. Points gapped at .020 J6C plugs at .030 16/1 premium gas(ethanol free). Low speed jet is around 1 1/4(+or-) out, high speed about 3/4 to 1 turn out. Here what's happening.. Fires up in the 'Start' position on choke, immediately push the choke in and runs better as expected. After a minute or so where it should be somewhat warm I start to slowly pull back the throttle and at mid point between 'start' and 'slow' it drops a cylinder. Throttling back up to start takes about a minute+ for the cylinder to kick back in. After repeating a couple times, it stalls and will not start. I pull the plugs, dry them off to check and it has great spark, have swapped the plugs, no change. I also checked spark in every throttle position. I may try regular 87 octane? I do NOT have a compression tester, that was my next guess, but it feels strong. When I had the exhaust plate off all piston rings had spring to them and cylinder walls looked very good. Any suggestions would be appreciated.
