I had a cranking issue that is now mostly fixed. Well now I got a different problem. My top cylinder suddenly has no spark. I swapped the coils and the problem did not follow the coil. In the process of re-routing the starter cableing, I pulled on the harness that goes to the ignition. Is there any way that I could have stopped only one coil by damaging the harness between the ignition switch and the motor? If not, are there any other ideas that I should try? (I know, get a manual! Working on it. What is the cheapest way to get a manual?)
I did use a spark tester, and the bottom spark is good and strong, the top one is non-existent even with a small gap set in the tester.
Thanks,
TerryMSU
Thanks,
TerryMSU
