I have a Johnson 35 Seahorse which i believe to be a mid 70s or 80s model, and I am having several issues.
1) Motor will idle fine, but once put into forward, and given throttle, it starts kicking out of gear and will ultimately go back into Neutral, where i will have to cut it off due to the rpms being way too high
2) I don't have full power. When throttle is all the way down, it seems like i'm only getting about 2000rpms or so
3) The lower end unit is leaking fluid, and there is a hole that is open, where the fluid leaks out. It is not threaded, so i am wondering how the hole got there, and if it is supposed to be there.
I have been told i need to check the dog clutch, and make sure its not worn, but have yet to do so. It seems like the throttle mechanism inside the engine is hard to move, so i may need to lubricate it, but dont know how.
Anyone with experience in these issues or have any input?
All help is greatly appreciated!
