Johnson 35 HP Electric Output
Measuring the three cables running off the generator (yellow, yellow-grey and yellow-blue) I have measured 12 Volts between yellow and yellow grey above 1500 RPM; approx. 5 Volts at idle speed - no measurements on yellow-blue. Before I buy expensive connectors and rectifiers ... anybody knows whether this measurements are normal, and what the amp. output of the engine at cruising speed is? Thank you !!
ross patti
Re: Johnson 35 HP Electric Output
Bongiorno,Walter...<br /> The best advice I can offer you is to get a manual that covers your engine.<br /> The information you are looking for will be in there.Along with tons more !!<br /> A library may also have a copy.<br /> <br /> Good luck
