Hi all,
This engine idles Ok but lacks power under load. So after checking zillions of things incl. ignition, spark plugs, fuel system and compression test (even on all 3) we have found the following issue for which we have no explanation:
There are 3 carbs/cylinders. Removing the air inlet box, we tested for vacuum at each carb inlet. We simply used a paper sheet. When covering top cylinder intake, there is strong vacuum, paper sticks to carb and engine dies fast (both at idle and with some gas). When covering mid carb, again paper sticks but engine do not die, but slows down quite a bit. When covering the lower one, no vacuum can be noticed, and no effect on engine idle or with gas whatsoever.
We shifted position of top and bottom carbs (thoroughly cleaned carbs in what seems to be very good condition) to rule out carb issue, and the problem is still the same and on the same cylinders. Gasket between carb and cylinder is new. We also inspected the flaps/valves (vacuum valves or what are they called?) and they seem to be in good condition and sealing well, all though we are not 100 % sure about that.
Finally we also tested with starter gas. When spraying in the lower cylinder, the one without vaccum, the rpm picks up. When spraying the other 2, no rpm increase, rather a bit of hesitation. We tried this both at idle and with some gas, same result.
Since we have decent compression ( 8.5 to 9 bars), strong sparks on all, and carb shift makes no difference, we feel it might have to do with the flaps/valves or some kind of air leak that ruins the vacuum totally on lower cylinder and somewhat on mid cylinder....??
Would be very grateful for some tips and ideas, this is driving us crazy. We even got hold of a OEM service handbook and did all the trouble-shooting tests it offered, but still same issue. So it starts and idle well but has no power, in fact it chokes and dies, when trying to accelerate under load. It does however rev well when in neutral.
Sorry for poor language, English is just my second language. Thanks in advance!
