update 2, Well, checked everything mentioned about, all checked out. Did a small adjustment to the throttle linkage, everything is tight. The one thing I found was the nylon piece that connects to the lower linkage and tiller gear was broken some how. This was causing the excess play in the linkage. I assume that the bumps would cause the time advance to move up and down causing the variation in speed. Not having any round nylon stock, I milled a piece of brass to replace the broken part Went out for a test ride today and everything seems to be back to running smooth.
Thanks for the help guys
