Johnson 25EL75B HELP!
dew2
I am lost with this motor!! Need some advice!
Motor has new coils,plugs,points, condensers,Fuel pump,Carb kit, Starts fine, the carb setting at 1 1/2 turns open gives the lean sneeze it stops at 3 turns open (the sneeze).I cant get it to idle to do fine adjustments,I get it down in RPMs and the throttle seems to have a mind of its own,It revs and slows with just a touch of the tiller twist throttle.I have checked the sync its in range of aligning with the mark when carb linkage moves.Timing light aligns with first mark on the right,Spark test shows great spark.I am running in a barrel, motor submerged 6 inches above impeller,compression at 93 and 96
I get it running easily (starting) higher revs no problem,when I slow down the revs, it responds and slows but then it just dies,its either higher revs or at slow it seems as though it will run at idle but dies.when I turn the throttle down near idle but yet higher RPMs the motor has its own mind it revs fairly high and with just putting my hand on the twist grip suddenly drops in RPMs and dies.ANY and all advice wanted and needed!!
Monte1961
Re: Johnson 25EL75B HELP!
I would check for air/vacuum leaks on,in and around carb! You can test this by spraying WD/40 or mixed fuel. good luck!
Cofe
Try pumping on the bulb, sometimes a weak fuel pump diaphragm won't work at low rpms.
AlTn
a clear fuel line from pump outlet to carb will help in determining air leaks in the fuel system..you should not have air bubbles present in this line with motor running
ultra353
Also when sraying the wd-40 around the carb, spray the crankcase halves to check for air leaks.
dew2
Sure appreciate the advice!! But when spraying WD-40 just what am I looking for? I got new fuel line clear and no bubbles in fuel supply,I sprayed wd all over but dont seem to see anything the reason for the question what do I look for when spraying WD-40??
ultra353
When spraying the wd-40 your listening for a change in rpms, which is an air leak comming from the specific area your spraying at.
AlTn
how much slop is there in the idle adjust screw at the end of the tiller handle?..also...marineengine.com..cyl. and crankcase..part no. 41..is it sheared or really loose?
