Johnson 25
pbduggins
I have acquired a used Johnson 25 Seahorse. The serial number according to the disc on the engine block is B2869/J25BAC1M. I am a novice with this type of motor so need as much information as I can get.<br />Main questions are - <br />2 or 4 stroke?<br />What fuel/fuel mix does it require?<br />Date of manufacture.<br />Service information e.g. plug type and gap, tuning tips etc.<br />It was used on a rescue launch at the local (freshwater) sailing club. It was serviced two years ago and has hardly been used since as there were starting problems.<br />CAN ANYBODY OUT THERE HELP ME?<br />Many thanks - Paul
bubbakat
Re: Johnson 25
1981 25 h/p johnson<br />plug champion QL77JC4 OR QL82C gap@30<br />fuel mix 50:1 tcw-3 oil
pbduggins
Re: Johnson 25
Thanks Cap'n! Another thing - is it important to balance the prop? Can I do it myself? I am planning to buy a set of flushing rubbers - you may know these things - they apparently clamp onto the shaft and enable you to run the motor out of water...I can't see an obvious water inlet - any ideas?
