I have a 1978 25 hp johnson on my pontoon, we were just crusing slow, 2000 rpm and failed to notice it was not pumping water ( has a new impeller and everything, also noticed some water comming out of the exhaust ports but no stream was shooting out the motor ). It sputtered and died,cranked it over and nothing. Upon checking the motor it was very HOT. Is there a over heat sensor or did I Smoke something. I just towed it home and parked it, next weekend I will pull it off and check compression and try it again, any ideas?
