Shooter Too
Thread starter- Joined
- Dec 1, 2002
- 7
I have a 1999 (date on engine is 12-08-98) Johnson J25REEN Serial number 04677730 2 cylinder 2 stroke outboard. I bought it used last February and have not had a problem until two weeks ago. It started missing at idle. The miss is not noticable at running speed. Sometimes the miss is accompanied by a backfire that shuts down the engine. The miss is worse at 1/4 throttle like when I am trying to pull away from the dock. That is usually when I get the backfire.<br /><br />While on the hose and idleing I can pull the lower plug wire off with no effect on the engine running. Putting the lower wire on and pulling the top wire shuts down the engine. I thought this indicated a bad coil so I replaced the bottom coil today with no effect. <br /><br />Where do I go from here?
