Johnson 25 3 Cylinder Problems
YL380
Hi there, I am new here but a long time lurker. I was hoping someone would have some experience with what I am encountering on a new motor that I received with a boat I just purchased.
The motor in discussion here is a 1998 Johnson 25 HP 3 Cylinder J25KLECA.
I can get the motor to fire up, but it will only start by using the primer system and dies shortly after. It will not idle, but I can rev it up for a second or two before it cuts out.
So far I have:
1. Changed inline fuel filter
2. Rebuilt and cleaned all carbs
3. Rebuilt the dual fuel pumps
4. Removed the automatic oiling system to ensure I was getting mixed fuel and oil to the motor
5. Tried running off a different fuel tank
Here is where it gets even more strange, I did a compression check and all three cylinders are exactly 60 lbs on the dot and verified with two different tools. I removed the head and inspected the cylinder walls and while the center had a tiny section .5" where it looks like there is some scoring they all look factory perfect with cross hatching still in place.
I then replaced the o-rings and sealed everything up exactly the way that it came from the factory. I tried pouring some marvel mystery oil in there to see if I could free up the rings, but I feel like I need to get the thing running long enough to create some heat in the motor and possibly free up the rings?
Any ideas at all? All input is greatly appreciated.
Honorary Supreme Mariner
Does spark jump an actual gap of 3/8" or more, yes or no ?----------That motor should run for more than a few seconds if the 3 carburetor bowls are full of fuel.
ondarvr
The only thing on your list that would have those symptoms would be the cab's, no fuel in the carbs, or at least not getting out of the carbs.
YL380
I haven't tried to check for spark in an open air type of test but I will. There is definitely fuel in the carbs.
You would think that even with the low compression numbers you could get it to idle for longer than a few seconds. It fires right up when the fuel primer is used.
Fed
It's common to have to bump the key to activate the primer until they warm up.
Bring it over I can fix it for you.----How did you adjust the low speed needles.-----How many turns out from seated, or did you set them to a dimension ??
YL380
I have the screw turned out 2 and a half turns on all three carbs. Is there a possibility that the neutral safety switch could be shutting it down?
The nuetral safety switch has nothing to to with spark.-------It prevents cranking when motor is in gear.------------The idle screws are not set by a number of turns out.---There is a dimension in the manual to adjust them to !!--That dimension is a value of 0.390 " directly quoted from the manual for these very nice motors.------The term " good spark " means nothing to me.------Does spark jump a gap of 3/8" or more, yes or no ??
