I have a 1986 Johnson 225 VRO that has a great deal of fuel blowing-back from the lower left (as you look at the carbs) carb when at idle. I have completely rebuilt the carbs, checked for fuel leaks, and compression is good on all 6 cylinders. The engine starts the first time with no problem, but then runs rough, coughs and spits and quits. The fuel bulb also goes weak. BTW the VRO is disconnected and I am mixing fuel. So 5 cylinders are pulling air and 1 is blowing out and discharging fuel. Has anyone seen this before?
Thanks for your help!
