Brownmule69
- Nov 23, 2010
- 45
MY Johnson 225 seems to have some type of fuel problem I think. I cleaned the carbs and they were clean but not when I first cranked it up and took off, it seemed like it wasnt getting enough fuel. It would run fine in Neutral but when I took off it would seem like it was getting fuel then not enough fuel. then finally will I got it planed off , it was still doing it. When I got up to 55 mph it wanted to cut back some. It was like it would go then slow down, go then slow down. Could this be the fuel pump bc I think its a fuel problem. At WOT, it used to run wide open but now it has some type of pulsation. Its like its not getting the steady flow of fuel but I have a new fuel filter and cleaned carbs. What else could it be? What is the average fuel pressure for that motor. Can you please help me? Thanks alot, WES
