Have 2000 Johnson 225 High output. The engine is not putting out full power at WOT. I can get about 5300 rpm's with a 131/2, 25 pitch four blade prop, and the GPS speed is 57 mph. I know several other people running the exact same boat and engine getting 5700-6000 rpm's with a 26 pitch prop and a GPS speed of 73-78 mph with about the same engine hieght as mine. <br /><br />The compressions are all between 95-92, spark to all cylinders, including at higher rpm's (though it was not checked under a load.) Every cylinder produce a rpm drop when the lead was pulled.<br /><br />what are somethings I should check. Could it be fuel related? Timing? Carb trash? need help, I'm missing 600 rpms and 15-20 mph.
