I have a Johnson 225 I believe to be a 1988 that caught fire a bit in air silencer and burnt up some primer lines and fuel lines. Does anyone have a diagram of how the hoses are routed to each other so I can double check that it is hooked up correctly. Also there are two larger nipples between the carbs. One is in the middle and the other is at the bottom of the intake manifold. Does anyone know what hose goes to those fittings.
