JJB
- Dec 28, 2006
- 274
I wanted to know if I replace the upper drive shaft bearing and seals as p/n 0439476 - Drive Shaft Bearing Housing and Seal Assembly . If I change it as a assembly bearing / seal / housing would it needed to be shimmed again . I was going to use the old washer , shim and thrust bearing , pinion and reinstall with new assembly . I have a seal leak there and bad bearing and though it be easy to just replace the whole thing as a P/n 0439476 assembly ... thank's for the help JJB [h=1][/h]
