hgvoce
- Dec 1, 2011
- 29
2000 Johnson 200hp Venom
The engine will not turn over and the trim does not work. The power trim relays buzz or click when trying to use the trim motor. I have replaced both relays with no change to the trim operation.
Ignition switch ohms out good, but the LEDs that should come on in the start cycle do not come on and motor will not turn over. Boat was recently purcashed from someone who rarely used it, was garage kept.
Looking for the starter fuse, where is it? Picture?
Thanks
Thanks
