Re: Johnson 200 charging system
The bad thing about having two batteries hooked in parallel (without an isolator) is that one may have a higher open-circuit voltage than the other (because of age, type etc.) This would cause one battery to drain itself while trying to bring the other up to its same level. In short, if your batteries are missmatched due to age, size or type, they MAY go down in charge when left sitting. Then when you start the engine, the charging system works for a longer period of time trying to bring them both up in charge. This even compounds if the engine is idled for a period of time once started, because the cooling to the rec/reg assmy. is lessened.(a weak cooling system can also contribute) For trouble shooting, just put a voltmeter accross the battery while the engine is running and see what the regulated voltage is. You should have the engine up to atleast 2000 rpm when you do this test. If the battery is up in charge as you say, you should measure atleast 13.8 volts while doing this test. If both batteries are hooked up during this test, and they are low in charge, it may take awhile for the voltage to reach this level. Regulated voltage is very subjective to the amount of current the electrical system is demanding. Regulated voltage should be checked with minimal electrical load. Checking the current output would require an ammeter (preferably a clamp-on) which would allow you to see if this charging system can produce its 30 amps. Turn on all accessories (engine rpm up to atleast 2000 rpm) and measure the current output right from the rec/reg unit. As in most charging systems, the hardest thing on them is high current requirements (low batteries or all accessories on) at low speeds.(poor cooling)
